regarding my clutch
Old Jan 31, 2005 | 02:00 AM
seanardy's Avatar
seanardy
Default regarding my clutch
tonight i tested my clutch if its really working fine and on changing gears its fine it change gears after i push the clutch pedal half way but on first and reverse you have to push the pedal alittle bit deeper like 1 1/2inch left before it reach the ground specially the reverse.and on first gear im wondering if how deep it should be on the pedal just for your car not to move when your on stop and on first gear without pushing the brake pedal?i need your help guys see if its just normal
