sunroof hiccups when closing
Old Sep 18, 2008 | 12:16 PM
whatneon's Avatar
whatneon
Default sunroof hiccups when closing
My sunroof stops when closing sometimes now. What should I look for with this problem, could it be debris in the track or cracked arms and or track? My fear is opening it back up to investigate and not getting it closed again. the subi legacy I drove had the right idea, a rod stashed in the console to manually crank it when trouble happened with the motors/switches.
Old Sep 18, 2008 | 05:03 PM
PSI Chick's Avatar
PSI Chick
the sun roofs have a habit of popping off the track. check that everything is aligned properly.
Old Sep 20, 2008 | 10:04 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
mine has popped off track before, no biggie. but as you said, wouldnt hurt to check to see if there is debris in there or something.
