drag racing rims
Old Feb 5, 2005 | 10:31 PM
Garza's Avatar
Garza
Default drag racing rims
Well, today was a complete waste of time. I spent all day at junk yards and didn't find a single PT. My next plan is to go aftermarket, but I don't know the offset, or what brand of rims will fit. I'd appreciate the help. Thanks
Old Feb 5, 2005 | 10:36 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: drag racing rims
Will neon rims clear the calipers on the SRT4? I should be running some 14" steelies off a neon on my baby, I just need to get the tires and wait for the track to warm up. I've already been doing burnouts.
Old Feb 6, 2005 | 02:04 AM
coyoteyz13's Avatar
coyoteyz13
Go to tire rack, and check the rims out for 15" snow tires.
Old Feb 6, 2005 | 02:57 PM
PSI Chick's Avatar
PSI Chick
14" will not fit, 15" will. you need a 5x100 bolt pattern and a 35mm offset for a 15" rim. that is the standard that will fit, but that is not to say that all rims that fit those specifications will fit.
vw steelies will also fit the car, if you can't find pt's try looking for those.
Old Feb 6, 2005 | 11:33 PM
Bruins013's Avatar
Bruins013
i use 15' roto subzeros with a small spacer...work pretty good
Old Feb 6, 2005 | 11:50 PM
moparturd's Avatar
moparturd
I thought I read somewhere that not all 15's would fit the calipers. Good luck in your search.
Old Feb 7, 2005 | 04:32 PM
drago354's Avatar
drago354
The VW steelies do fit. I use my stock wheels from my jetta. I have two spare steelies if you're interested.
Old Feb 9, 2005 | 12:51 AM
BigMac's Avatar
BigMac
You can also try here: http://www.car-part.com/
