boost leak!!!!!!!!!!!!!!!!
Old Feb 17, 2005 | 12:23 AM
alisrt4's Avatar
alisrt4
Default boost leak!!!!!!!!!!!!!!!!
how do i check if my car is leakin boost?
it used to hold boost on 15 when i first bought it but after i got my downpipe installed i rarely see the boost on 15, is my turbo spoolin different right now
whats the deal?
Old Feb 17, 2005 | 12:40 AM
PSI Chick's Avatar
PSI Chick
Default RE: boost leak!!!!!!!!!!!!!!!!
Boost Leak Tester
make one of those and pressure test the system.
did you use a gasket when you installed the dp? you also need to retighten the bolts on the dp after a few heat cycles. that would be the first thing to check, but it's always a good idea to check the whole system for leaks anyway.
Old Feb 17, 2005 | 10:59 AM
glhs837's Avatar
glhs837
If you've dropped 1-2 psi, I think that's a side effect of the downpipe. but like chick said, it never hurts to do a leak check. For our cars, a 2 inch plumbing coupler at Lowes is a perfect fit, comes premolded with clamps already installed.
Old Mar 1, 2005 | 10:24 PM
jopar4's Avatar
jopar4
i read in sport copact that the computer is set up for the stock piping. when the sensors see less back pressure the computer throws a fault cutting back on the boost to save the motor, because it thinks something is wrong with the car. They said they had to go to stage 2 , because it is designed with the mopar catback (which is bigger,and causes less backpressure) in mind. go to sport compact project srt-4 for more info. hopefully you will not the the stage 2. good luck
