engine light on
Old Jan 13, 2009 | 03:20 PM
SRTUNIT2's Avatar
SRTUNIT2
Default engine light on
engine light came on after a stop at a stop sign then will driving engine began to sputter. turn car off then tried to turn on again and just would turn over but not caught then starts rev to 2000-2500 and wld start to sputter again. CAN ANYONE HELP! or am i on the way to the dealership? thanks
Old Jan 13, 2009 | 09:33 PM
Unique Designs's Avatar
Unique Designs
I can help.... start by the key trick.... turn your key to the on position 3 times quickly without starting the vechicle... once you do this immedialy look at your gauge cluster where your milage is and then you will see a code come up. this will be the code your computer threw it will start with a p... example P00344 or something like that... it might be multiple codes. do that then let me know what code it is
Old Jan 14, 2009 | 08:53 AM
SRTUNIT2's Avatar
SRTUNIT2
thanks anyways took to dealership and was covered under warranty. cam shaft position sensor was the problem. that is a cool trick though and will keep in mind if need again.
Old Jan 14, 2009 | 01:03 PM
Unique Designs
yup glad i can help... i build neon srts so i know pretty much alot of stuff and tricks with them.
Old Jan 19, 2009 | 09:55 AM
PSI Chick's Avatar
PSI Chick
so who's cars have you built?
Old Jan 19, 2009 | 04:44 PM
Unique Designs
i have done a bunch of friends cars... from build bottom ends to top to all boltons to powder coating
