upgrade question
Old Jan 12, 2009 | 01:30 AM
gottalovethesrt's Avatar
gottalovethesrt
Default upgrade question
I have an 05 srt and I wanted to get a AGP 50 Trim kit. My question is if I were to get the 50 trim kit would I still be able to get the mopar stage 2 upgrade in the future? Also along with the 50 trim kit what other upgrades should I get along with that?
Old Jan 13, 2009 | 12:51 PM
STILL GH3TtO's Avatar
STILL GH3TtO
why would you want the stage 2 as well? The stage two only upgrades the waste gate and he injectors. To put a 50 trim your gonna need all the support mods like 255 fuel pump, injectors, some sort of fuel and boost controller and preferably and exhaust, motor mounts, I am sure I am missin some other random stuff as well.
Old Jan 13, 2009 | 01:50 PM
Unique Designs's Avatar
Unique Designs
honestly there is no reason to run a stage 2 computer with a 50 trim..... you can run the stock computer and get a tunning device like the diablo and use that to tune everything... the injectors that come with the stage 2 are a little to small for a 50 trim... you need at least 750s........the upgrades you will need for a 50 trim would be, walbro 255 fuel pump, rc 750 injectors, intake, exhaust, bov, and something to tune with...
Old Jan 14, 2009 | 09:19 AM
PSI Chick's Avatar
PSI Chick
the s2 injectors are actually perfectly fine if you have a return line
Old Jan 14, 2009 | 01:06 PM
Unique Designs
ya the stage 2s will work but can put out alot more power with r/c... the mopar stage 2s dont flow enough and are not flow tested they say 683cc but there more like 590. flow rate... people are using 1000cc now with 50trims and stuff and getting about a 40hp difference over stage 2/3
Old Jan 14, 2009 | 02:27 PM
drewthatsmenb's Avatar
drewthatsmenb
when i had my 50 trim in my other srt this was my set up. 50 trim kit, 3 inch turbo back, aem intake, s-afc neo for tuning, 2 step colder plugs, crane cams 8.5mm firewires, walbro 255 pump, rc 750 injectors, hard intercooler pipes with hks ssqv, i had the dogbone mounts and the tranny mount but you don't "need" them, hallman boost controller, apexi turbo timer and a occ i'm pretty sure i ran some other mods but i haven't had that car in a couple of months now so i don't really remember but those are some of the basic mods you will need o and i would recommend you get a fuel return line o and you'll need a wideband to help you tune
Old Jan 16, 2009 | 12:24 AM
Unique Designs
yup right on the money
Old Jan 19, 2009 | 09:54 AM
PSI Chick's Avatar
PSI Chick
i'm sorry but 1000cc injectors on a turbo as small as a 50 trim is retarded. people are just looking to waste money at that point. that's way overkill.
Old Jan 20, 2009 | 12:42 AM
drewthatsmenb
^agreed
Old Jan 20, 2009 | 12:05 PM
Unique Designs
ya agreed it sounds stupid but there no difference in price on injectors you can get 300cc injectors for the same price you get 1825cc so your not wasting money.
