Grinding sound under the hood
Old Mar 1, 2009 | 01:35 PM
SFontaine54's Avatar
SFontaine54
Post Grinding sound under the hood
I have a 2004 srt4 with sum upgrades nothing to crazy over the last 3 weeks I have noticed a grinding sound under the hood when I come to a stop I don’t think it is my brakes because it happens when I’m costing also.... it sounds like when the car is started already, and you try to start the car again (if you know what I mean) but just not as loud... if you have any idea let me know thanks......
Old Mar 3, 2009 | 02:12 AM
neonftw87's Avatar
neonftw87
when your car is making this noise, try pushing the clutch.... if it stops when you push the clutch, your throwout bearing is going out.... if this is the problem, then may as well change the clutch with it.
could have a break caliper stuck, anytime your brake shoes are metal to metal, it will roar, but it will get worse when you push the brakes.
other than that, i dont know what else it could be, i hope this helps you out bro... good luck
