what do you think is better?
Old Mar 6, 2005 | 08:01 PM
seanardy's Avatar
seanardy
Default what do you think is better?
i just had my car this year and i already put 1 occ on it and im just wondering if i really have to put another one or put a breather from valve cover to the intake since i still have the factory intake.right now im trying to put all the stuff thats gonna make my car last.i need suggestion guys....ty
Old Mar 6, 2005 | 09:12 PM
Gump's Avatar
Gump
Default RE: what do you think is better?
I would... i need to find a fitting to get my second on mine.. when i took my intake off last time there was oil in it and its sticky as hell and i couldnt get it clean.
Old Mar 7, 2005 | 12:11 AM
casper's Avatar
casper
Its not necesary, but its a good idea.
Old Mar 7, 2005 | 12:38 PM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: seanardy
No. You only need to get a second OCC if you have a CAI or a short ram. Since you have the stock intake/airbox you don't need a second OCC and it would be a complete waste of time and money if you did. The OCC's are to keep the oil out of the wrong part of the engine, the PCV line goes straight into the intake manifold so it need an OCC for it. But the other line goes into the airbox and not into the intake tube, like it does with a CAI or short ram, so the oil that comes from it will just run down to the bottom of the airbox, it cannot get into the intake/engine.
Old Mar 7, 2005 | 12:58 PM
PSI Chick's Avatar
PSI Chick
or just get a intake that removes the line from the valve cover to the intake and put a breather filter.
Old Mar 10, 2005 | 07:52 AM
71RoadRunner
That will work too. I haven't found a cap that will fit my CAI's hose fitting or I might go that route, but I've talked to a guy that had his set up that way and he had a problem with oil dripping from his filter.
Old Mar 11, 2005 | 01:10 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: 71RoadRunner
The filter on a breather will get oily if used alone on the crankcase. I installed a second catch can before the breather. It hardly ever needs to be emptied, but does slowly accumulate oil. My filter is sparkling clean.
So, Seanardy, I would say, you don't need one with your stock airbox, there is a sponge in there sopping it up, and it is outside of your intake tube, but if you do an aftermarket intake, like 71rr said, you will need one - I suggest a $20 oil catch can, then a breather.
Old Mar 12, 2005 | 12:48 PM
seanardy's Avatar
seanardy
thanks guys..i just came back from cruise so its kinda delay for me to reply back.thanks again
Old Mar 13, 2005 | 02:02 AM
black4's Avatar
black4
kinda interested in getting an occ my self still undecided.
Old Mar 13, 2005 | 08:12 AM
71RoadRunner
Getting an OCC is pretty much a must, especially after you see how much and how fast the oil collects in it, and then to think that it was all going into your engine and getting all over the parts that it's not supose to and also burning it[:'(].
