the shift knob
Old Mar 9, 2005 | 05:12 AM
blast*baby's Avatar
blast*baby
Default the shift ****
whats the deal with the way out shift **** pops on an off my father was shiftin when i just got it an it came right off what can i do to change that....
Old Mar 9, 2005 | 06:45 AM
scottw03's Avatar
scottw03
Default RE: the shift ****
Alot of people have had that problem. You can get a replacement **** from Modernperformance.com which is pretty nice (about $49.99 - http://www.modernperformance.com/dcx...hiftknob.shtml ) or you can contact a guy named Gerry on srtforums.com and he can make you a custom on with whatever design on the top of the aluminum ball. Some guys have a club called SRT-4mation and they got that engraved in their ****. Looked pretty nice. I am thinking of getting one but need to come up with what I want on it. Those are some thoughts. Good luck
Old Mar 9, 2005 | 11:26 AM
glhs837's Avatar
glhs837
Alternatively, pull back on the ****, not up. Absolutely prevents popoff
Old Mar 9, 2005 | 07:09 PM
blast*baby's Avatar
blast*baby
i kno that im just sayin i wish it wasnt like that an i wanted to kno if ne1 knows where i can get it chpopped a lil bit an get threads put on so i just have one that screws on. can you just imagin ****in too hard or pullin it an it flyin out your hand an out your window or in the face of someone in the backseat. it would be funny yes but i personally am a worry wort an i think the worst of everything
Old Mar 9, 2005 | 08:15 PM
OrochiDio1's Avatar
OrochiDio1
if your puling ur shifter off then your trying to hard.
Old Mar 9, 2005 | 08:32 PM
glhs837's Avatar
glhs837
Really, BB, use this as a trainer, popping off the **** is an indicator that you are not operating it properly. Like falling off a balance beam. We don't add inches to the balance beam, we balance better
Old Mar 9, 2005 | 11:41 PM
scottw03's Avatar
scottw03
ORIGINAL: blast*baby
If you are pulling on it that hard to pull it off then I highly doubt that your grip on it is going to be so weak that it is going to go flying anywhere.
Old Mar 10, 2005 | 08:22 AM
71RoadRunner's Avatar
71RoadRunner
I've put in the Mopar STS and my shift **** is still on good and tight and has never came off on me.
Old Mar 10, 2005 | 11:31 AM
200srt4's Avatar
200srt4
i have heard about many people having that problem, but all the people with SRT-4's I know, and myself have never experienced that!
Old Mar 11, 2005 | 01:03 PM
posthondaremoval's Avatar
posthondaremoval
Definitely shifting wrong, you don't need to SLAM the car into gear, and even if you do, shifting back into second, you should try more to position your hand on top of the shifter with your fingers in the front and just sort of push the shifter into second. I race cars, and it is better to shift with a soft hand. Touch is everything. It sounds like you are manhandling it a little much.
Added note - the shifter from modern is a good upgrade. The significant increase in weight IMO makes the shifter feel better and fall into gear a little easier. There are other vendors who make a metal **** as well; I just have Moderns's and like it.
