map sensor low code
Old May 4, 2009 | 05:58 PM
tenzunit's Avatar
tenzunit
Default map sensor low code
I keep getting this code whenever i hold 20+psi and when i hard decel. I have a 2004 with agp50trim, rc750 injectors, boomba fuel rail, aero regulator and return, walbro fuel pump, SAFC2, 3bar map and tip. I just ordered a map clamp to see if it will help. does anybody have an idea on what is causing this code?
Old May 22, 2009 | 10:43 AM
jnmopar71's Avatar
jnmopar71
Lightbulb your code
you need stage one!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
