msd ignition and coil opions
Old Mar 14, 2005 | 07:29 PM
black4's Avatar
black4
Default msd ignition and coil opions
just curious to see how everybody feels about that set up and what kind of difference it made.
Old Mar 15, 2005 | 03:14 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: msd ignition and coil opions
ORIGINAL: black4
Haven't tried the coil, yet, but the wires make all the difference in the world. The car used to studder at idle real bad, and Simply changing the wires (at like 3000 miles) made the car purr like a kitten. The wires have like 1/600th of the resistance as stock.
Old Mar 15, 2005 | 03:49 PM
black4's Avatar
black4
sweet thanks post.
Old Mar 16, 2005 | 04:06 AM
PSI Chick's Avatar
PSI Chick
don't bother with the coil. it's just a red version of the stock one. we actually have a very good stock coil pack, don't waste your money on getting an afermarket one that performs just like the stock one. in some cases, the stock coil is better than the aftermarket ones.....
Old Mar 16, 2005 | 06:49 PM
black4's Avatar
black4
what about the ignition system it self?
Old Mar 16, 2005 | 09:09 PM
TX SRT MAN's Avatar
TX SRT MAN
i'm at 60,800miles, should I change my coil pack? i already have the MSD on order, but if I dont need it right yet, i'll just save it till i may need to swap.
[IMG]local://upfiles/4313/F7FDAD6E05004BDDA1ED43B7AA5AC756.jpg[/IMG]
Old Mar 16, 2005 | 09:58 PM
PSI Chick's Avatar
PSI Chick
again, don't bother with the coil pack. there's nothing wrong with the stock one, and it performs as well and lasts longer than the aftermarket ones.
as for the ingition system itself, what would be your purpose for using it? people are using it, but unless you're going to get for it a specific application, there's not really a need for it.
Old Mar 17, 2005 | 09:05 AM
71RoadRunner's Avatar
71RoadRunner
The MSD wires are a great upgrade, but the MSD coil has the exact same output as the stock coil, so get the wires and use the money you would have spent on the coil on something else.
