turn down boost??
Old Jun 13, 2009 | 08:26 PM
mxrnick's Avatar
mxrnick
ok now that doesnt sound like the wastegate anymore it sounds like the wastegate giving you too much boost but if the gauge doesnt show it and the cars not pulling hard untill the sputter then i dunno i must be something else. you might have a boost leak check all the vacum lines and make sure they are all still connected. after that you are going to have to think of anything you did before it started this and when did you first notice it
Old Jun 13, 2009 | 09:14 PM
tyler819's Avatar
tyler819
ok i will def check all my lines and check for boost leaks. I think u might be right because it doesnt even get past 15lbs of boost and messes up, and it started doin that after i changed the waste gate adjustment and it was boosting fine before i did that and i havent got it back to how it was since. I guess i shouldnt even have messed with it
Old Jun 14, 2009 | 02:13 PM
mxrnick's Avatar
mxrnick
my geuss is the boost got to high when you were setting the wastegate and it popped a vacum line off or something
Old Jun 14, 2009 | 04:06 PM
tyler819's Avatar
tyler819
all of the lines around the battery look intact but i still have to check behind the battery and around the turbo, probably gonna have to take off my intake to get to them.
Old Jun 14, 2009 | 06:34 PM
mxrnick's Avatar
mxrnick
yea you will probly have to take off the intake but my geuss is its one of the lines on the turbo
Old Jun 14, 2009 | 09:42 PM
Jims04srt's Avatar
Jims04srt
While checking for boot leaks, look at your plugs and reset the pcm. I'm sure you have a boost leak, but it never hurts to check everything.
Old Jun 15, 2009 | 01:03 AM
mxrnick's Avatar
mxrnick
thats what im sayin has to be a boost leak jims right check everything try intercooler piping look every where if you can get under the car that helps alot too
Old Jun 15, 2009 | 09:28 AM
tyler819's Avatar
tyler819
I am going to take off the intake and look around today to see if I can find anything, I'll post back if I find anything but that seems what it must be.
Old Jun 15, 2009 | 04:20 PM
tyler819's Avatar
tyler819
I went to dodge today and they have a very good service manager there that knows a lot about srt4's and he told me right away that i messed up the calibration on my wastegate since stage 2 wastegates should not be adjusted, so he recommended a new stage 2 wastegate to fix my problem. I ordered an agp wastegate from modern perfromance instead so hopefully this fixes what has happened.
Old Jun 16, 2009 | 01:00 AM
mxrnick's Avatar
mxrnick
im sure it will its nice being able to tune the boost at the spin of a screw. i didnt even think you could adjust the stage 2 but i geuss you can i think ive heard the spring is to soft so it will never really get the boost up that high but i dunno thats just what ive heard i think
