new to american tuner
Old Jun 29, 2009 | 12:11 AM
70x7's Avatar
70x7
fuel pressure regulator. They arent necessary, but i would for nitrous (my opinion).
A different manifold wont work with the stock turbo as they are both halves of the turbo itself. Sounds funny what I am saying, but the exhaust manifold actually has a large hole for the blades of the exhaust turbine to sit in (eh, if you saw it you would see what Im saying). Basically, stock turbo=stock manifold. Aftermarket turbo=aftermarket manifold.
Old Jul 3, 2009 | 02:32 PM
dgk12589's Avatar
dgk12589
ive never really dragged b4 can anyone tell me how to do a perfect launch with an srt 4?
Old Jul 3, 2009 | 10:34 PM
mxrnick's Avatar
mxrnick
if its stock you need to rev it up to like 2500-3000 feather out the clutch as you get on the gas. its not an on/off switch so get on the gas smoothly or you will just spin the tires other than that good luck and practice makes perfect
Old Jul 3, 2009 | 11:24 PM
dgk12589's Avatar
dgk12589
this may sound dumb but what does feather out the clutch mean? does it mean let it out slowly? im not used to a stock clutch in an srt-4 i had a prelude that ran high 12's with a stage 3 6 puck clutch that i would rev up at about 3500 rpms and just drop it and it would hook right away so this is kind of new to me
Old Jul 4, 2009 | 01:37 AM
mxrnick's Avatar
mxrnick
feathering means you kinda bounce the clutch petal out slowly letting it a little bits at a time i dunno its kinda hard to explain. this is only for a stock srt-4 because it has to much torque and the car will wheel hop through first. mine has motor mount inserts that eliminate the wheel hop so i can rev it up to like 3000-3500 and just let the clutch out slow enough to not spin the tires. what did you have to do to a plelude to make it run high 12s cause they are no where near that stock?
Old Jul 4, 2009 | 12:19 PM
dgk12589's Avatar
dgk12589
o my prelude was no where near stock. i had an sh that was a full turbonetics turbo kit with a upgraded fuel pump fpr lsd carbon fiber hood i think golden aries pistons but not sure they came with it and stage 2 cams full 2.5" exhaust with no cat a stage computer called hondata i think it also came with it and it had a couple other things it was mostly built when i bought it i just put on the turbo and it had the stage 3 clutch. it ran a 12.8 at the route 66 track in joliet.
