50 trim question
Old Jul 6, 2009 | 06:46 AM
night709's Avatar
night709
Default 50 trim question
I was wondering what the modification that you need to run it properly w/o starting to break things.
Current mods- Borla exhaust, AGP Wastegate, Perrins fuel return line, NGK Spark Plugs, Manual Boost Controller, HKS Turbo Timer, MSD Spark Plug wires, Stage 1 kit, Front and Rear Strut bars, aftermarket suspension, AEM Cold Air Intake, Short shifter.
Believe that is it.
Old Jul 6, 2009 | 10:51 AM
70x7's Avatar
70x7
with just the turbo kit itself it will run just fine. Its how far you push it without the right mods that makes the difference.
oh, you probably do want an external bov though
Old Jul 6, 2009 | 05:17 PM
phattysrt's Avatar
phattysrt
X2, depends on how far you want to push your car... more air requires more fuel. you will be limited to how much how boost you can run with the stage 1 injectors. I would highly recommend you invest in a AFR gauge like the aem uego, new injectors (650 cc or 750 cc), high flow fuel pump and of course a proper tune and a weigh to tune it. You can install your turbo but verify your air to fuel ratio isn't too lean or rich. Good luck
Old Jul 7, 2009 | 01:28 AM
night709's Avatar
night709
Ok, I just don't want to have it get installed and start to break things.
I forgot to add that I have an HKS BOV and an Exceddy Sports Package Clutch.
Old Jul 7, 2009 | 07:29 PM
Jims04srt's Avatar
Jims04srt
Def get an AFR guage, larger injectors and some tuning software.
