Idling rough...running lean need help
Old Jul 12, 2009 | 11:41 PM
Kapitald's Avatar
Kapitald
Default Idling rough...running lean need help
P0171-FUEL SYSTEM 1/1 LEAN
Im throwing that code....I dont know how or where to diagnose my problem...Its idling so rough at idle that it sounds like a v-8 camming. At wot my air fuels are in the 12's working up to 13's when they used to be in the safe 11's.
Im going to get a cheap set of stage one injectors off a forum member and swap them out to see if that fixes it...apparently im running lean somewhere...could my stock fpr be a problem?
Any help appreciated...Im pretty positive plugs and wires are good.
Old Jul 14, 2009 | 10:35 AM
70x7's Avatar
70x7
perhaps the fuel pump is failing
Old Jul 14, 2009 | 12:57 PM
Kapitald's Avatar
Kapitald
It starts up good every time and drives me where I need to get to and never dies. Is there anyway I can troubleshoot this stuff?
Old Jul 14, 2009 | 03:43 PM
70x7's Avatar
70x7
"A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak downstream of the MAF sensor. "
Old Jul 15, 2009 | 07:11 AM
Kapitald's Avatar
Kapitald
where is the MAF located?
Old Jul 15, 2009 | 01:24 PM
70x7's Avatar
70x7
Its the sensor located on top of your intake manifold. 2 short torx screws hold it in. Wires trace up underneath the injector cover.
FYI
Ours is a MAP sensor (Mass Air Pressure) as opposed to a MAF which is sensing flow. Same function. The MAP sensor compares signals to the TIP ( I believe it stands for Throttle Inlet Pressure) sensor which is located in the UPP. When signals are way out of wack, a CEL is thrown. This is very common once boost controllers are added.
Old Jul 16, 2009 | 12:28 AM
Kapitald's Avatar
Kapitald
I was wondering why you wrote "MAF" when all I know is MAP and TIP and TPS
Well my car isnt throwing a bunch of codes and running like crap...just the one code for running lean. I need to do a fuel pressure test but im unaware of how to go about doing it.
I checked the injectors today and they all seem to be fine.
Old Jul 16, 2009 | 11:05 AM
70x7's Avatar
70x7
Basically its just a gauge you can put inline. Any shop could do it.
Perhaps your 02 sensor(s) are beginning to fail....just throwing out other suggestions.
