high rpms
Old Jul 24, 2009 | 10:19 AM
Kapitald's Avatar
Kapitald
Well the hard pipe on the bottom (passenger side) is the hotside pipe or lower pressure pipe.
The pipe that goes to the throttle body (driver side) is the coldside pipe or upper pressure pipe. This is the pipe that will have the HKS flange...
Just throwing that info out there because I thought you said your bottom side was bad...maybe you are replacing both.
Anyway exhaust depot is great. They can put a hks flange on it. I think its just exhaustdepot.com
Old Jul 25, 2009 | 06:06 AM
night709's Avatar
night709
Yea, sorry about not adding that part of the info in. It is the upper pressure pipe. So far it seems like the ones I find are around $170.
Old Jul 25, 2009 | 06:32 AM
night709's Avatar
night709
I was looking at like:
http://cgi.ebay.com/ebaymotors/Press...QQcmdZViewItem
or
http://www.modernperformance.com/upp...t4-p-1887.html
What do you guys think would be better? The one from exhaustdepot.com is at $235.
Old Jul 27, 2009 | 06:16 PM
Pressurecooker's Avatar
Pressurecooker
If you dont know the Key on Key off trick you need to learn it! It will show you codes without a scanner or special pin tool or having to take it "in". Mopar has had this feature from the beginning of time. I love Mopars for this reason among many others.
Now get with the program son!
Old Aug 1, 2009 | 12:56 AM
night709's Avatar
night709
I know the key trick but I was asking which pipe you guys thought I should get though.
Old Aug 1, 2009 | 09:50 PM
70x7's Avatar
70x7
doesnt really matter. Follow your pocketbook grasshoppa
