What the hell should i do?
Old Mar 29, 2005 | 01:40 PM
  #21
TFXFalcon's Avatar
TFXFalcon
Default RE: What the hell should i do?
is ther a way i could just get the stage 1 pcm and not the injectors cuz my srt is an 05 and already has them. any place where i can buy just the pcm?
Old Mar 30, 2005 | 11:09 AM
  #22
71RoadRunner's Avatar
71RoadRunner
If you have an '04 or '05 and you order the Stage 1 you only get the PCM, you do not get the injectors since they are already installed on your car from the factory. Only the Stage 1's for the '03's come with the new larger injectors.
Old Mar 31, 2005 | 01:45 AM
  #23
BigMac's Avatar
BigMac
Yep -- although they charge the same for the PCM alone as they do fo the PCM + injectors. Go figure...
