hks bov install need help..please
Old Apr 14, 2005 | 01:28 PM
04srt4lvr's Avatar
04srt4lvr
Default hks bov install need help..please
i got a new hks bov and now i dont know wihich vacuum line i need to use . do i use the one that was on the original bov or do i "y" off a different vacuum line . frustrated
Old Apr 14, 2005 | 03:49 PM
PSI Chick's Avatar
PSI Chick
Default RE: hks bov install need help..please
cap the pink like that runs to the wga. you want to t into a line by the throttle body as a vacuum source.
Old Apr 14, 2005 | 06:03 PM
04srt4lvr's Avatar
04srt4lvr
when you blocked off the factory piece did you use any sealant b/c i didnt.
Old Apr 14, 2005 | 06:07 PM
PSI Chick's Avatar
PSI Chick
do you mean on the bop? yes, i did use sealant.
Old Apr 14, 2005 | 10:24 PM
04srt4lvr's Avatar
04srt4lvr
i put a t on the line and it works now but its overboosting way past 20psi ....any help with that
Old Apr 15, 2005 | 02:50 AM
PSI Chick's Avatar
PSI Chick
what other mods are on the car? what else did you change that could possibly cause this? have you checked for boost leaks? did you reset the ecu?
