wot shift and heel-toe help with srt4
Old Apr 21, 2005 | 12:50 PM
coyoteyz13's Avatar
coyoteyz13
Default RE: wot shift and heel-toe help with srt4
Left foot braking is fun as well. I used to race karts and the only way to break is with your left foot.
Old Apr 21, 2005 | 02:21 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: black4
wot shifting still kicks my but i cant shift quick enough to keep up with rpms and just wondering what kind of time gain would you see using this tech over traditional shifting?
Probably about 2 tenths of a second. I wouldn't do it too often, though. There is always the time when you miss, no matter how good you are, but I guess the rev limiter will keep us from doing any real damage. Gotta' love one thing, though, mopar did us a favor by giving us a 6500 rpm redline when we shift at like 5700, that extra headroom is a nice cushion.
Old Apr 21, 2005 | 07:34 PM
whoosh's Avatar
whoosh
thx guys
Old Apr 29, 2005 | 12:36 AM
Frankie Newport's Avatar
Frankie Newport
ive heard of left foot braking before but what is its purpose?
Old Apr 29, 2005 | 08:00 AM
roachnigga's Avatar
roachnigga
Left foot braking is to xfer the brake bias to the rear of FF cars. In other words to prevent understeer. Does that help?
ORIGINAL: Frankie Newport
Old Apr 29, 2005 | 02:33 PM
Frankie Newport
kinda...so do u do it in the beginning of the corner or in the middle?... and i assume u keep ur right foot on the gas to control the weight transfer, right?
Old Apr 30, 2005 | 03:00 AM
Black SRT's Avatar
Black SRT
ORIGINAL: posthondaremoval
Really, the point of heel toe shifting is as coyoteys13 said, but to add to his explanation, the goal is rev matching. You don't want any change in momentum in turns when downshifting, and heel toeing it enables you to get the gears moving before you let out the clutch so you can keep up speed, and have no jerkiness while you are at high cornering loads.
I can and do, do it in the srt-4, but the setup makes it tough. The steering wheel is too low to move your leg freely while you twist your foot. Putting the wheel a little higher helps, but I don't like the position for driving, personally. The pedal placement is also less than perfect, but it can be done.
wot - you leave the gas fully depressed while you blip the clutch and shift the gear. It takes timing, but definitely works well. Kinda' pointless with s0, It is a s1 and 2 feature that holds the boost while you do this. It will reward you with quicker acceleration and a loud pop, maybe a flame out of the tailpipe.
Wrong if you have an 04 or an 05 you have boost hold on the WOT. I know for sure because I have a BOV and it will not blow off if I do it. Thats just one more reason the 04's and 05's are better than the 03's. Oh if you hear the loud pop, you just hit the rev limiter and lost all your boost.
Old May 1, 2005 | 06:33 PM
roachnigga's Avatar
roachnigga
I do mine as im entering the middle of a corner. and you're correct on your second statement
Old May 2, 2005 | 11:38 AM
coyoteyz13's Avatar
coyoteyz13
You can also trail brake though most of the turn by keeping your foot on the brake and dragging the brake slightly with your left foot. if you are running fast around a turn, do lift the throttle and brake. You can upset the car and lose control. Some guy did that on SRT forums and flipped his car.
Old May 4, 2005 | 04:55 PM
roachnigga's Avatar
roachnigga
ouch[]
