Stage 1
Old May 5, 2005 | 08:58 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Stage 1
Yep, and the same happened with Stage 2 and then Stage 3 when they came out.
Old May 5, 2005 | 10:54 AM
dolem20's Avatar
dolem20
Default RE: Stage 1
I got mine in 2 weeks modernperformance.
Old May 5, 2005 | 11:19 AM
Silverrt4's Avatar
Silverrt4
Default RE: Stage 1
Dolem20, The stage 1 that you got in two weeks from modern performance, is that the one that you posted as being bad pcm already, in another post? If so what the news with that anyways. My TPS was screwy too, only b/c the wires running to it were so short that when there was any kind of torque the wires would pull out and become loose. My ground wire came loose and that cause the same problems you are haveing. Check to see if the wires running to the TPS are bent the completely oposite direction of the way they are going into the TPS.
