$20 catch can?
Old May 4, 2005 | 03:34 AM
avengermike's Avatar
avengermike
Default $20 catch can?
okay will i think i have all i need for this mod, only question i do have is the home depo guy gave me polyethylene tubing. i told him i needed it to hold up to gas and oil. does anyone know if this will work?
i will be flying ou to AZ to get my car at the end of the week and would like to put this mod on at the dealer ship for my 8hr drive back, the trip will take of break in.LOL can anyone think what else i should do befor my trip home?
Old May 4, 2005 | 07:32 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: $20 catch can?
Most any hose will be fine, it just vents crankcase gases with a tiny bit of oil.
Old May 4, 2005 | 02:02 PM
posthondaremoval's Avatar
posthondaremoval
Actually the gasses are too hot for the poly tubing (the clear stuff, right?). There has been a little discussion on this. They will leach fumes and contaminate the system slightly ( not that big a deal, really, but I don't want to take chances.) since they aren't rated for high temp. useage. Although I would like clear tubing so I could see what's all going on in there, I haven't found a clear high temp tube yet in the size we need. I used good old black high pressure line that can be had at any autoparts store.
Old May 5, 2005 | 01:29 AM
avengermike
okay took the clear stuff back and got transmission oil cooler hose, those pep are crazy tried to sell me some fuel inject hose 4ft came to 24.00.
Old May 5, 2005 | 09:17 AM
71RoadRunner
I believe that dustyloins has had clear tubing on his from day one of his OCC and megaman has clear hose on his.
Old May 5, 2005 | 02:03 PM
posthondaremoval
ORIGINAL: avengermike
They tried to get me with that $24.00 pre packaged stuff, too. HA!!!! Good call on the oil line.
Hey Dusty/megaman, you out there? What kind of tubing did you go with? I couldn't find clear high temp anywhere.
Old May 6, 2005 | 01:06 AM
teddeath2000's Avatar
teddeath2000
I used Clear Pressure waher hose 3/8" worked great ( at tractor supply or Home Depot)
Old May 6, 2005 | 02:11 PM
posthondaremoval
ORIGINAL: teddeath2000
That stuff - while it can hold the pressure no problem, isn't made to withstand heat. You are (like I said, whether it matters or not) slowly leeching poly fumes into your system. The stuff does degrade at temp. If there was a high temp clear tubing, I would use this, but other than REAL expensive acrylic stuff, I haven't found it.
Old May 7, 2005 | 07:51 AM
71RoadRunner
I haven't seen either of them on here in a while.[]
