how much boost?
Old May 9, 2005 | 12:19 PM
TeamRedLine's Avatar
TeamRedLine
Default how much boost?
I just got a 2005 srt-4 and I was woundering how much boost that they are running stock and what is the max they can handle? this is my first car with a turbo as well a my first dodge so I dont know that much about them. And also, will a 2003 or 2004 part work on a 2005? thats what I heard.
thanks
Old May 9, 2005 | 12:34 PM
PSI Chick's Avatar
PSI Chick
Default RE: how much boost?
stock they run 11-13psi. the stock turbo can take about 18-19psi. bigger turbo's can run around 32psi or more. with the exception of the stage kits, all 03 - 05 parts are exactly the same.
Old May 9, 2005 | 08:42 PM
TeamRedLine
thanks for your help. one more thing, how much boost can the stock internals handle.
Old May 9, 2005 | 08:47 PM
PSI Chick's Avatar
PSI Chick
well, psi levels are dependant on the turbo size, fuel, engine management, etc., so it's not a matter of how much psi it can handle, but rather how much hp/hq it can deal with. as long as the fuel delivery is addressed properly, the stock internals are good for about 550-600 fwhp.
i know numerous big turbo cars running 32-34 psi putting out 400+ hp. one particular comes to mind that's running 34psi on high boost, 25psi on low boost. we don't know exactly what his hp is (he doesn't believe in dynos), but i'm guessing around 600hp. he's on stock internals.
Old May 10, 2005 | 01:08 AM
LilSparkPlug's Avatar
LilSparkPlug
Stock turbo doesnt flow well past 19psi.
Today with it being cold and all I was boosting 14-15 strong (stock). I'll get 11-15 depending on weather and elevation. These engines are damn strong, they can handle alot of what you throw at them if they're supported properly.
Old May 15, 2005 | 06:25 AM
Hellboy's Avatar
Hellboy
i can't hardly get my boost up past 5,barly to 10 if ever, it's either me or the roads are to short. or the car is screwed
Old May 15, 2005 | 07:38 PM
PSI Chick's Avatar
PSI Chick
hellboy - you probably have a boost leak. run a check on it and then reset the ecu.
Old May 15, 2005 | 11:29 PM
teddeath2000's Avatar
teddeath2000
I bought a 2005 , 1400 miles on it. between 13-15 is what I am getting. It is acccording to temperature, fule, etc. I dont know where you live or what octane they have but my car runs 10 tims better on shell or Chevron 93 ?? Shell ( and I know it seems weird) but I seem to get 15 at times 16 ? sunoco 13, screw swifty or speedway ( I call it stranded gas) lucky to get 12
Old May 15, 2005 | 11:37 PM
Hellboy's Avatar
Hellboy
i don't suppose you could tell me how the test might be done?
Old May 16, 2005 | 02:56 AM
PSI Chick's Avatar
PSI Chick
read this, it goes over the basics on how to build a leak tester and use it. if you have any other questions just ask
