Battery
Old May 18, 2005 | 05:34 AM
Biopulse's Avatar
Biopulse
Default Battery
http://www.odysseybatteries.com/battery/pc680mjt.htm
Good stuff? Or no / so-so? Better one?
Old May 18, 2005 | 04:49 PM
SRT4STYLIN's Avatar
SRT4STYLIN
Default RE: Battery
Cant really tell ya, never heard of them...
How much is that battery?
Old May 18, 2005 | 07:16 PM
Biopulse's Avatar
Biopulse
Default RE: Battery
I've seen it on some different sites, and mostly it's in the area of a hundred bucks. There are some batteries that are lighter weight too if you search a bit for it. The lightest one I saw was about 13 lbs, the mounting bracket is an aluminum 1 lb bracket with the odessey battery and it's small enough to fit in your glove box so you can save it from the engines heat to make it last a bit longer or you could mount it in the trunk somewhere.
