Car idling rough since Prothane inserts install?!
Old May 20, 2005 | 07:14 PM
SRT4STYLIN's Avatar
SRT4STYLIN
Default Car idling rough since Prothane inserts install?!
Alright guys,
I put the inserts in last night, and enjoy how it has change the response from my engine and lack of wheel hop.... BUT I have notice that my car is idling a little rough since last night, and I am wondering if that is vibration produce from the lack of give in the motor mounts now???
Has anyone else felt this, and if so, is this to be expected?
I dont mind how it is running, I just want to make sure that something is not wrong!
Thanks
Andrew
Old May 20, 2005 | 07:18 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: Car idling rough since Prothane inserts install?!
Yes its to be expected with any type of motor mount modification, except the rex inserts, with which you reall notice no difference. With certain solid mounts its even WORSE. But no nothings wrong with the car, its just stiffer than it was before, causing more vibration. Even something so small as an energy suspension insert or prothane insert can do that to it.
Its all good, no worries
Old May 20, 2005 | 07:40 PM
SRT4STYLIN's Avatar
SRT4STYLIN
oh ok,
Thats what I figured was going on... Its not that I mind it, its just different, and different scares me sometimes!!!
Thanks for you help
Andrew
Old May 21, 2005 | 02:46 AM
LilSparkPlug
Yeah I hear you on that one. Sometimes different is good, but in my case its usually bad!!! [:'(] Your very welcome, thats what we're here for.
Old May 21, 2005 | 03:32 AM
Gump's Avatar
Gump
wait ill you turn on your heater... youll get this loud grinding sound.
Old May 21, 2005 | 04:00 AM
LilSparkPlug
lol yeah.....hopefully there wont be a need for heat anytime soon. (hopes) After this winter I dont want another one for A LONG time. Solid mounts give you that annoying power steering whine too. [:@] Thats why im thinking inserts myself
Old May 21, 2005 | 06:18 AM
71RoadRunner's Avatar
71RoadRunner
And when you turn on the A/C or defroster you'll feel and perhaps hear the A/C compressors clutch as it kicks in and out, so don't freak out when this happens.
Old May 21, 2005 | 02:28 PM
roachnigga's Avatar
roachnigga
Is is worth getting the inserts or MM?
i see this topic as annoying with having those mishaps
Old May 21, 2005 | 07:17 PM
LilSparkPlug
Solid mounts are worse than inserts when it comes to the noise. But if you don't really want the wheel hop and all the engine movement that goes along with the stock mounts, you probably should consider either one. Especially if you take it to the track and drive it hard.
Old May 22, 2005 | 01:23 AM
lblackneon's Avatar
lblackneon
I still haven't installed my Prothane Motor Mount Inserts (Race). Do you all think that is going to be that bad? I know vibrating is expected but hopefully it's not that bad.
