Thermostat Mod?
Old May 27, 2005 | 12:58 PM
PSI Chick's Avatar
PSI Chick
Default RE: Thermostat Mod?
overall the car runs just fine with the 195, it's at the track and when racing that you benefit from the lower temps.
Old May 27, 2005 | 03:27 PM
posthondaremoval's Avatar
posthondaremoval
PSI Chick, are you running a fan switch mod as well? Just wondering, since I thought that there would be little benefit from a 180 stat when standing still without it. Running, I am sure that it is beneficial, and on the road course, I am sure it makes a difference, just wondering about the strip and if anything addl. is needed to realize any improvement.
Old May 27, 2005 | 03:36 PM
PSI Chick's Avatar
PSI Chick
i am not running the fan mod. too much of a chance of me forgetting to turn it on! i'm researching another product that allows the fans to work automatically, but also incorperates a switch for the track to allow the fans to be turned on at will.
Old May 27, 2005 | 03:37 PM
roachnigga's Avatar
roachnigga
JUST FINISHED ORDERING ONE!!
Old May 27, 2005 | 03:55 PM
PSI Chick's Avatar
PSI Chick
ordering one what?
Old May 27, 2005 | 04:01 PM
posthondaremoval
ORIGINAL: PSI Chick
That is exactly what I have been looking for. I want it to work as normal, with a bypass that lets me turn it on when I want if the occasion should arise.
Old May 27, 2005 | 04:10 PM
roachnigga's Avatar
roachnigga
thermostat
Old May 27, 2005 | 07:14 PM
whoosh's Avatar
whoosh
where does it go? how do you install it?
Old May 28, 2005 | 06:40 AM
roachnigga's Avatar
roachnigga
its goes right under ya radiator cap. remove the two bolts and there it is.
Old May 28, 2005 | 12:06 PM
black4's Avatar
black4
so radiator fluid getting everywere when installing it wont be a problem then and how much diffeance did it make.
