How to tell Stages
Old Aug 30, 2010 | 03:17 PM
  #41
Sceneiskeen's Avatar
Sceneiskeen
Im going to go to advanced and get them to check the codes.
from what i understand, it throws a code becuase the car doesnt have cats.
Old Aug 30, 2010 | 03:48 PM
  #42
70x7's Avatar
70x7
Actually that is what compressor surge sounds like but look at your wideband. It bounces to 16 a/f!!! No wonder the car is doing that, its trying to save itself from the lean condition.
Turn your key to on without starting it 3 times in a row off and on and your code will pop up in the display. post what code that is.
Is that orange thing a boost controller? If so turn it all the way off for now
IF you do have the S1 ECU, it will not matter if you have cats or not. The S1 is programmed to ignore the secondary O2 sensor. If it is a code because of the cat, then you do not even have an upgraded computer.
Old Aug 30, 2010 | 03:49 PM
  #43
blacksunshine05's Avatar
blacksunshine05
that could be. put you can just turn your key to the on position then off, then on, then off, then on again and it will put the codes on the dash. it will start with P then a four digit number. the car sounds like it has a very bad boost leak. but not sure never heard something like that.
Old Aug 30, 2010 | 05:48 PM
  #44
mxrnick's Avatar
mxrnick
does the car have a boost controller of some kind? i would also say make sure all the vac lines are correct and none of them are cracked and leaking at a fitting.
Old Aug 30, 2010 | 09:33 PM
  #45
Sceneiskeen
i did that the A/f Gage showed Ren u06, and P00. and the boost gage showed u04.
and yes there is a boost controller.
can you get me a picture of all the vac lines ?
Old Aug 30, 2010 | 10:22 PM
  #46
70x7's Avatar
70x7
those displays on the a/f meter I have no idea what that means...
did you turn off your boost controller? Sounds like you are overboosting to me...that would explain your fuel cut, your compressor surge, and your CEL
Old Aug 30, 2010 | 10:32 PM
  #47
Sceneiskeen
honestly i have no idea if its off or not, when i say i bought the car as is, i did. Im a chevy guy, straight muscle cars. I have no ideas about turbos boost or boost controllers. ima cut the boost down with the **** and see if fixes it.
Old Aug 30, 2010 | 10:39 PM
  #48
70x7's Avatar
70x7
then do this. Take the 2 lines from each side of the boost controller and connect them together and remove the device. This will take out the boost controller. Either that or turn the bc fully closed and run it.
Do you still have the factory solenoids in place? There are 3 and were originally in place in front of your airbox. Knowing this would help us trouble shoot your vaccum lines better.
Old Aug 31, 2010 | 12:03 AM
  #49
blacksunshine05
Here is a picture they want you just to run a tube from the turbo to the wastegate.
Old Aug 31, 2010 | 12:10 AM
  #50
Sceneiskeen
Ok. i got in the car, and i pushed the left button on the Tru boost gage and held it for a few seconds and it said, OFF. After that the car was driving fine, wasnt doing the stuttering anymore. i even got it to boost up to i want to say 9 or 10 psi
so im thinking somehow the truboost gauge has the boost set to something the car cant handle. how do i use the adjuster in the hood? or what would i need to do to program the boost gage to work correctly?
