wheel hop
Old Aug 25, 2010 | 08:37 PM
rickyrod33's Avatar
rickyrod33
Default wheel hop
i get wheel hop driving in 1st and 2nd gear alot in parking lots... what are the best motor mounts to stop wheel hop?
Old Aug 26, 2010 | 12:49 AM
blacksunshine05's Avatar
blacksunshine05
The cheapest way is this below which is an insert. You can get either street or race insert.
http://www.modernperformance.com/pro...on-p-1131.html
Or if you race the car and want all your wheel hop gone then solid mounts are the best you can get. But the car will vibrate more with solid mounts.
http://www.modernperformance.com/sol...on-p-1130.html
Old Aug 26, 2010 | 01:48 AM
rickyrod33's Avatar
rickyrod33
true... are the solid mounts alot better than the inserts? how bad is the vibration?
Old Aug 26, 2010 | 03:36 AM
blacksunshine05
I have the solid mounts and solid transmission mount. You are going to get more of a vibration in the car then normal with solid mounts because the solid mounts transfer the vibration from the engine to the body of the car. So that depends on if you mind that or not. For me it is not that annoying so I live with it. Solid mounts are better then the inserts, I have had both. But the inserts will give you less vibration. If you dont want a lot of vibration go race inserts.
Old Aug 29, 2010 | 02:20 PM
mxrnick's Avatar
mxrnick
i have inserts and they got rid of my wheel hop. its worth the 25 bucks to try the inserts first. i have heard peolpe say the solid mounts create a lot of vibrations but that is a matter of opinion. i took out my balance shafts and that creates alot of vibrations but still fine for me. its up to you but i would say try the inserts first cause they worked great for me. heres a link to a site i trust.
http://www.maperformance.com/prothan...rts-srt-4.html
Old Sep 1, 2010 | 02:03 PM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
Good info.
Old Sep 1, 2010 | 04:35 PM
rickyrod33's Avatar
rickyrod33
Default thanks
i wanted to say thank you for the replies greatly appreciated.. wheel hop is kinda frustrating... i think im guna try the inserts first then move one to the solid motor mounts if im not satisfied..
Old Oct 2, 2010 | 03:08 PM
rickyrod33's Avatar
rickyrod33
Default inserts
how many inserts should if come with i clicked the link and it only had 2 inserts on there want to now the quanity i should get
Old Oct 3, 2010 | 12:56 AM
mxrnick's Avatar
mxrnick
2 is all you need 1 for the top and 1 for the bottom for most kits like the ones listed above but some kits like i have come with 4 pieces 2 for each top and bottom i geuss they both work the same i dont know.
Old Oct 4, 2010 | 04:27 PM
70x7's Avatar
70x7
depending on the kit, you should have a tranny mount insert also.
Ive had both and granted the inserts are alot more "comfortable" but they didnt solve all the problems. Solid mounts took more of the hop away, and at first I really didnt like them because of the added vibration, but give them a few to settle and it mellows out.
Of course other factors play into wheel hop also...tires, clutch, power levels, etc...
