how much downforce dose spoiler provide
Old May 31, 2005 | 01:44 AM
coyoteyz13's Avatar
coyoteyz13
Default RE: how much downforce dose spoiler provide
The SXT wing has a little bit of a lip at the back of it. Our's doesn't. That is sure to make downforce.
Old May 31, 2005 | 02:15 AM
jameshushek's Avatar
jameshushek
but the wing is so small there probably is no way its gonna help you at higher speeds, they didnt maky it that high for the supra look now did they, they tested it provin it built it and use if for a reason besides what other kinda wing will show off our curves as well? Change it if you want but dont lose control at 12o mph.... that could suck!
Old Jun 2, 2005 | 12:47 AM
morningpride's Avatar
morningpride
Adam,
You can really feel it stick at 130?
Wow, if that's the case, props to DCX for actually making it functional and not just for looks!
Old Jun 2, 2005 | 01:10 AM
glhs837's Avatar
glhs837
As I recall, the story is that the marketing guys insisted on a wing, so the team said, fine, if we GOTTA have a wing, it'll work at least.
And for the record, while an upward angled will produce down force from the airflow acting on it, like PHR said, an upside down wing shape (flat on top, curved on bottom) will produce "negative lift" also.
I recommend howstuffworks.com for some good animations on lift.
Old Jun 2, 2005 | 04:27 AM
Barneydriver's Avatar
Barneydriver
ORIGINAL: posthondaremoval
Definitely has an effect. I have done numerous high speed runs, and surprisingly, at 135 in long slow turns the car is stuck like glue. It is stable at 150+ and the spoiler's vertical strakes do as much to keep the car stable as the inverted wing helps to keep it glued to the ground.
Here is a link to a thread where I broke it down. A number of people who are pretty knowledgable chimed in as well:
http://www.srtforums.com/forums/show...=wing+inverted
In my post I said th following:
Guys, science says the wing does create downforce. Read the following blurb about how an airplane wing creates lift. Then look at your wing. It is shaped like an upside down airplane wing. The fact that the upper surface on our wing is flatter and the bottom is curved indicates that it will create a low pressure zone on the bottom, thus creating downforce. I think it is hard to refute these facts.:
Lift is the aerodynamic force that counteracts gravity and holds an airplane in the air. Most of the lift required by an airplane is created by its wings, but a certain portion is also generated by other parts of the aircraft, such as the fuselage. But what actually causes the lift to be created?
First, understand that air is a fluid, just like water, and that all fluids adhere to the same physical and mathematical principles. Next, realize that lift can only be generated when a fluid is in motion. For example, a wing must be passing through the air or the air must be moving around a stationary wing, one or the other. (The way it usually happens is that the wing is doing most of the moving, although the air may be moving too, at the same time.)
Most airplane wings have a special, basic shape as viewed edge-on: their upper surfaces are curved and their lower surfaces are flatter. This shape is what works with the fluid motion of the air to create lift. As air moves around a wing, some goes over the top and some goes underneath. The air that goes over the curved upper surface undergoes two important changes: it is reduced in pressure (by the centrifugal force of flowing across the curved surface) and it is accelerated downward (as it leaves the trailing edge of the wing). The wing is forced into the region of reduced air pressure above the upper surface of the wing by the higher air pressure beneath the wing. Also, the downward acceleration of the air (downwash) at the trailing edge forces the wing upward.
^^^^^I think that this explains pretty well, "How" the wing works.
Chrysler has tested it to produce around 100 lbs of downforce over 120.
you're talking about my world- i love this stuff. i'd say you've given a great explanation of bernoulli's principal. i would only say that the air leaving the trailing edge of the wing produces more drag than lift. on most airfoils the air never makes it to the trailing edge of the wing, as the laminar (smooth) flow departs most wings about 2/3 of the way back (depending on the aoa (angle of attack), of course) and turbulates out into the slipstream (that's why you'll see the little fins on the back of the commuter jets sticking up about 2/3 of the way back on the wing- these are vortex generators, which cause the air to spin like a tornado, which in turn causes it to follow the contour of the wing further back, increasing efficiency- for a more relevant example, look at the back of the evo viii mr- same principal- they keep the air attached to the car farther back, increasing the efficiency of the wing).
the pricipal states that the fluid flowing over the curved surface of an airfoil will travel faster than the fluid flowing over the flat surface, in order to rejoin at the same point at the same time at the trailing edge. this creates a low-pressure area above the faster moving fluid, and the rest is as you said. there are two schools of thought currently as to what the force is that actually creates the primary lift on a wing- some think it is the high pressure area under the wing pushing up, some think the low pressure area over the wing pulling up. i happen to think it's both- i think a lot of guys are going that direction (so i guess that makes three schools, actually).
airplanes actually use the inverted wing- the horizontal stabilizer on the tail is an inverted airfoil- this keeps downforce on the rear of the plane to help keep the nose up (to put it simply), so yes, it definitely works.
so, the question is, will you notice a difference at speed? well, i was going to take mine off until i went canyon carving w/a bmw k1200 (a bike)we were smashing curves at about 140 the whole way up, and my car felt glued to the ground the entire time- i never once got loose in the rear- since then i've decided i'd better keep my spoiler, b/c i figure if it works don't f... with it.
wow- this thread is more info than you ever wanted to know about wings, eh? i love it!
Old Jun 2, 2005 | 03:15 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: glhs837
Look who it is!!!welcome back.
Old Jun 2, 2005 | 06:22 PM
glhs837's Avatar
glhs837
In relation to your talk of laminar flow, Barney (who'd a thunk an ordnanceman talking laminar flow, eh?) I think that was one reason for the height of the wing, was to be in the airflow after it departed the rear of the body.
Old Jun 2, 2005 | 06:28 PM
posthondaremoval
Now, would a vortex generator coupled with an sxt wing have a similar effect to the srt wing?
Also, I wonder if Just adding a vortex generator as is would help or hurt, since the wing is up in the air a bit to begin with.
I know - a rear diffuser will do all that and more, with it's undermounted tunnels, but I was just thinking. (I need a wind tunnel, now)
Old Jun 2, 2005 | 09:33 PM
morningpride
Ok, you lost me there?????
Old Jun 3, 2005 | 05:41 AM
Barneydriver
ORIGINAL: glhs837
yeah, i've always figured that's why they did that- kind of like the old roadrunner, was it? i can't remember which one it was with the huge wing on the back. it definitely makes sense.
gotta design bombs to move through the air too, right? wait, is it ordinance guys who don't like to be called bomb guys? i always forget...
