racing inserts..
Old Oct 2, 2010 | 12:17 PM
rickyrod33's Avatar
rickyrod33
Default racing inserts..
what are the best raceing insert motor mounts to get? that will reduce the wheel hop as much as possible?
Old Oct 2, 2010 | 01:32 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Get some solid motor mounts like ones from AGP. For a softer ride, go with inserts like ones from Porthane.
Dusty
Old Oct 2, 2010 | 02:52 PM
rickyrod33's Avatar
rickyrod33
Default motor mounts..
true.. i just dont want alot of vibration.. is it that bad wit sold mounts?
Old Oct 2, 2010 | 05:23 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Depends on your idea of "bad". You can also try "racing inserts" instead of "street inserts" which would probably be somewhere in the middle. I think Prothane makes those as well.
Dusty
Old Oct 2, 2010 | 06:26 PM
rickyrod33's Avatar
rickyrod33
Default inserts
i think im guna buy the racing inserts how many should it come wit cause i was on this site for the perothane ones and it only showed 2 of them under quanity should i get 2?
Old Oct 2, 2010 | 08:51 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Go to modernperformance.com and enter "inserts" in the search window for the SRT-4. They have a "walk-thru" video that shows installation and other things you need to know.
Dusty
