Water injection?
Old Jun 11, 2005 | 04:15 AM
Biopulse's Avatar
Biopulse
Default Water injection?
How safe is it to run this in an srt-4, I know PSI Chick has talked about it before as an no2 alternative, but I haven't seen too many posts about it.
Old Jun 11, 2005 | 04:44 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Water injection?
I've seen one at the track that uses it, but that's it.
Old Jun 11, 2005 | 06:14 AM
PSI Chick's Avatar
PSI Chick
it's a lot safer than nitrous. the point of water injection is to reduce egt's, as well as allow you to run more timing and reduce knock. it's not really a power adder, it just allows you to more effectively use what the engine is already putting out. you will see increases on the dyno and at the track due to it however.
Old Jun 11, 2005 | 08:31 AM
black4's Avatar
black4
you know who sells it psi ?
Old Jun 11, 2005 | 02:07 PM
PSI Chick's Avatar
PSI Chick
cooling mist and snow performance are the two main companies
