Motor Mount Socket Size?
Old Jun 12, 2005 | 07:19 PM
Bob96's Avatar
Bob96
Default Motor Mount Socket Size?
I installed by Red Prothane upper motor mount insert = 18mm socket. Slipped right in with not problems. Before I take off my front wheel and spash guard to install the lower I see that the socket needed for the lower is larger. I don't have one that big and need to go out and purchase one prior to the install. I am guessing 22mm? Does anyone know the socket needed for the lower stock motor mount bolt?
Thanks
Old Jun 12, 2005 | 07:57 PM
Biopulse's Avatar
Biopulse
Default RE: Motor Mount Socket Size?
http://dodge-srt4.com/howto.shtml
They have the service manual up here online for download.
Edit: not sure if the size in mm is in there, if you have dial up don't bother downloading it, it's huge.
Old Jun 12, 2005 | 09:43 PM
morningpride's Avatar
morningpride
I would have to guess 21mm,
Sorry, it's to damn hot here to go and lay under the car to check!!
