Stock BOV issues
Old Jun 15, 2005 | 06:40 PM
black4's Avatar
black4
Default RE: Stock BOV issues
is it holding 18 psi to red line?
Old Jun 15, 2005 | 07:36 PM
PSI Chick's Avatar
PSI Chick
can you take a picture of the wga please? if the car had a boost controller on it then it most likely had (or still does) an aftermarket wga. if you removed the mbc and did not adjust the wga accordingly this could be causing the high boost levels.
