Knocking noise help
Old Mar 23, 2011 | 10:22 AM
elmuffler's Avatar
elmuffler
Default Knocking noise help
I have an 04 srt-4 with 55,000 and I hear a knocking noise going over bumps and sometimes when I turn my mechanic couldn't find wrong when he checked it out. But it's annoying. Brakes are good and so are the bushing
Old Apr 21, 2011 | 04:59 PM
Moparmatt440's Avatar
Moparmatt440
Have you done anything to the suspension? Check the torque on the lower knuckle in the front that holds the lower control arm to the spindle. I can't remember the exact tqr spec I think its 45-50 ft lbs
Old Apr 22, 2011 | 08:52 PM
elmuffler's Avatar
elmuffler
no i haven't done anything to the suspension. but the driver lower ball joint was bad and got it replaced and the control arm. but i still hear a knock on turns i herd it can be the steering rack also but i don't see any leaks
Old Jun 1, 2011 | 10:10 PM
wolf22m's Avatar
wolf22m
If it is while turning, then probably a CV shaft
Old Oct 1, 2011 | 05:29 PM
turbo2point4's Avatar
turbo2point4
does it happen when going over bumps? i know the rear struts make noise, they do it from the factory, if thats it, its normal
