Help with PCM clips
Old Jul 1, 2005 | 03:58 AM
SRT4@40's Avatar
SRT4@40
Default Help with PCM clips
I screwed up & broke a black clip for the PCM. I had no idea they were there! How, or where do I get a replacement tab, or can they be fixed? I really do not want to put the ghetto fix in there! (Zip ties)
__________________
Old Jul 1, 2005 | 07:01 AM
roachnigga's Avatar
roachnigga
Default RE: Help with PCM clips
was you installing a new PCM? If so, get it from the old PCM. If not, the PCM is a firm fit. If wanna feel more comfortable, you can use elec tape
Old Jul 1, 2005 | 12:30 PM
coyoteyz13's Avatar
coyoteyz13
I think you can order a new harness, but it is pretty expensive. I did the same thing. Fixxed it with zip ties. SRT4@40, sorry about what happenned on SRTforums.
Old Jul 1, 2005 | 12:50 PM
PSI Chick's Avatar
PSI Chick
what happened on srtforums?
zip ties are your friend.
Old Jul 1, 2005 | 01:04 PM
coyoteyz13's Avatar
coyoteyz13
It is not that big of a deal. I really don't want to get into it.
Old Jul 1, 2005 | 01:09 PM
SRT4@40's Avatar
SRT4@40
Do you have tozip tie all the way around the PCM? no problem coyoteyz13!
Old Jul 1, 2005 | 01:19 PM
coyoteyz13's Avatar
coyoteyz13
I ran a big zip tie around the PCM from top to bottom. I ran one for each conector. Good luck, I was pissed when they would not stay in place after I broke the clips. If you don't have big zip ties, you can connect a few little ones together.
Old Jul 1, 2005 | 03:06 PM
SRT4@40's Avatar
SRT4@40
Thanx man; I never thought to run one from to to bottom, I was just thinking around each connector!
