Torque Steer Type Feeling on Accel.?
Old Jul 10, 2005 | 04:34 AM
Bob96's Avatar
Bob96
Default Torque Steer Type Feeling on Accel.?
I have a 2005 with just over 1000 miles. I have added; AEM Short Ram - Borla Exhaust - Maxfab 3" DP - Removed 2 1/4" section at front of Borla - Stage 1 PCM - Stage 2 WG - MSD Coil & Wires - NGK Iridium Plugs @ .040 - Octane Booster for CA 91 gas.- Prothane Red Motor Mount Inserts. My Butt Dyno says I have a lot more HP than stock. I have noticed something lately somewhat like Torque Steer in a Muscle Type Car? When I hit the throttle hard in 2nd gear my car turns slightly to the left and then to the right? My GF said "Why are you steering like that?" but I am holding the wheel firmly and in a centered position. The amount of turn is not great but is noticable and a little scary!
Do all SRT-4's do this? Is it caused by my Limited Slip Diff. shifting power back and forth from one wheel to another? I will certainly be carefull in wet weather,
Old Jul 10, 2005 | 03:35 PM
black4's Avatar
black4
Default RE: Torque Steer Type Feeling on Accel.?
welcome to the world of overpoweed front wheel drive.you should see how bad it is for me and a cant even begin to imagine how it is for psi.
Old Jul 10, 2005 | 07:40 PM
TFXFalcon's Avatar
TFXFalcon
hahah hell yeah torque steer!!!!!
Old Jul 11, 2005 | 02:18 AM
orangesrt's Avatar
orangesrt
I am still stock and i get alot of torque steer in first and even some in second gear.
Old Jul 17, 2005 | 03:40 AM
teddeath2000's Avatar
teddeath2000
same here
Old Jul 17, 2005 | 03:45 AM
LilSparkPlug's Avatar
LilSparkPlug
Surprisingly I get none. Ive been in my car with my best friend driving, and it doesn't pull either way at all. My only performance mods are 3" Custom exhaust (no cat no res), AEM Shortie, and Stage 1 (well Mopar Noisemaker too but that doesn't count).
And yet still....nothing. The only thing my car does, is if your taking a corner from a dead stop and get on it as if your cutting someone off the wheel will stick in that position until the throttle is released. My car is SUCH a crackbaby.....it does things it shouldn't, and what it should do, it doesn't.
