Overboost srt4
Old Jul 25, 2011 | 07:38 AM
GchyeaSRT4's Avatar
GchyeaSRT4
Default Overboost srt4
I have a 2003 dodge srt4 and im throwing code P0234 "overboost"?
Recently i bought a coldpipe with a greddy bov flange so i bought a universal "greddy"(pos) and it flutters instead of the purgin sound I want? I only have a cold air intake too..no big mods at 5 1/2 rpm in 2nd i backfire and my car throws the engine light n i check it and it says P0234"overboost"
Old Sep 24, 2011 | 12:55 PM
turbo2point4's Avatar
turbo2point4
boost turned up past 17psi? i think the pcm throws that code when you boost over 17psi, other wise are all vac lines hooked up?
Old Sep 25, 2011 | 01:02 PM
GchyeaSRT4's Avatar
GchyeaSRT4
I havnt played with the boost level...Iv only put a block off plate on and a cold pipe with a wanna be "greddy" bov but its a no name bov, that also "flutters" it doesnt do the swoosh sound.. And i do not have an adjustable waste gate..its still stock..and all vacuum lines are hooked up...
Old Sep 25, 2011 | 05:25 PM
DOHC_97's Avatar
DOHC_97
unhook battery for a few mins to reset the ecm. mine did the same thing and reseting the ecm fixed everything.
Old Sep 26, 2011 | 02:59 PM
GchyeaSRT4's Avatar
GchyeaSRT4
Ive done that everytime I take the car apart..but ontop of that, my stock boost gauge stopped working also
Old Oct 1, 2011 | 05:05 PM
turbo2point4
the gauge might have just went bad, or the line going to the gauge may have come unhooked, another thing to check for the overboost code would be check and make sure all the vac lines and rubber connections are in good shape, i think the overboost code is tripped when the tip and map sensor see different pressures, but it could be something wrong with your bov i suppose, if the red line is hooked up in the cold side pipe before the bov it would see a higher psi than in the intake manifold due to a leaking bov, not positive that is it but its a thought.
