stage 2 boost level?
Old Jul 19, 2005 | 03:10 AM
jtaylor1856's Avatar
jtaylor1856
Default stage 2 boost level?
I have S 2 installed just wondering what the highest boost level should roughly be. I'm only boosting 12psi. I have the Mopar BOV installed but i don't think that would cause me to loose more then 1-3 psi, correct?
Old Jul 19, 2005 | 11:53 AM
t0973mf's Avatar
t0973mf
Default RE: stage 2 boost level?
At least 17psi. Did the dealer install that BOV also? Could be leaking. Somethings not right. I read your other post about their install job and they suck. As much as you had to pay for that install, I hope they make it right.
Old Jul 19, 2005 | 12:18 PM
PSI Chick's Avatar
PSI Chick
when i had s2 i spiked 21psi and held 19
Old Jul 19, 2005 | 03:14 PM
roachnigga's Avatar
roachnigga
Sweet! the most i spiked was 19 held @ 17.5
Old Jul 19, 2005 | 03:22 PM
posthondaremoval's Avatar
posthondaremoval
I am spiking 19-20 and holding 17.5.
Damn, PSI Chick, 21 adn 19 is pretty impressive. Was that with the s2 wga?
Old Jul 19, 2005 | 03:42 PM
jtaylor1856
I installed the Mopar BOV. But could that be leaking that much . I'm ony boosting 12psi with S2
Old Jul 19, 2005 | 03:55 PM
posthondaremoval
ORIGINAL: jtaylor1856
sure it could.
did you use the gasket and also tighten it down to proper torque?
Also - have you checked all of your intercooler plumbing for leaks?
You could set up a leak tester for next to nothing, and find out where it is if you want, as well.
For a great write up on boost leaks on this car read:
http://www.srtforums.com/forums/show...ht=leak+tester
Old Jul 19, 2005 | 05:18 PM
BlackDragon's Avatar
BlackDragon
ORIGINAL: posthondaremoval
Yes that was with the s2 wga. We just had the right combination to get the power out of 21/19. If somebody tries to go that high without the supporting mods to take advantage of it, it will hurt performance more than help.
it was good for 273/304 on a dynojet uncorrected with the stage 2 pcm yanking the bejeezus out of the timing. and on pump gas...
Old Jul 19, 2005 | 05:21 PM
BlackDragon
Do you have toys or no? Did you pressure test the system? When you look at the bov, does the stock surge valve look bent where the bolt are? Did you pressure test the system? What other mods do you have on the car? Did I ask if you pressure tested it yet?
LOL
Old Jul 20, 2005 | 01:45 AM
jtaylor1856
Yes I have Mopar toys. No I haven't pressure tested the system. I checked all of the hoses from the intake to the intercooler and from the turbo to the intercooler. I'm going to make the pressure tester tomorrow, just gotta get the stuff to make one. With the surge valve i can see a little gap between the bolts on each side of it, but it looks like the rubber seal in the surge valve would make a tight seal. Maybe not let me know. I have an apointment on tuesday neaxt week to have everything checked out at the dealership but would rather beable to fix it myself so i don't have to travel 40minutes.
