2001 Neon ES SRT4 Swap
Old Oct 17, 2011 | 04:49 PM
Billy Leavitt's Avatar
Billy Leavitt
Default 2001 Neon ES SRT4 Swap
I am looking to do a SRT4 engine and trany swap in to my 2001 Neon ES.
I am wondering if any ove you know what kind of modifications will i be looking at having to do to complete the swap.
Old Oct 17, 2011 | 05:30 PM
turbo2point4's Avatar
turbo2point4
i have never done it but i believe the swap is bolt in, and you may wanna swap the engine harness, pcm, and any other SRT part you can get your hands on to use, generally the more complete the swap the better
Old Oct 17, 2011 | 05:34 PM
turbo2point4
i just thought about it though, if you go to a srt pcm youll need a sentry key which, means the key would need programmed to the vin number that you would have programmed in the pcm to match the car, not sure what other parts are involved with making the sentry key part work i'm sure some sort of module to check the key then tells the pcm its the correct key, so it may be easier if you can't do that to use the ES pcm but of course you would need some way to tune it then, i'm not sure what the pcm connectors on the '01s are like though compared to the SRT's maybe it would all just be plug and play, check neons.org, or srtforums.com theres multiple people on those forums that have actually done the swap you could talk to, or even how to's
Old Oct 17, 2011 | 07:00 PM
Billy Leavitt
I do plan on getting the everything the wiring harness everything just to complete the swap. i am getting a settlement in the next few months from a car accident i dont want to have to go out and spend around 10k on a SRT4 neon if i can do the swap for under 6k and plus i love my car i just the turbo engine and what not! is there any to find out what all ill need to do the swap? and if its even possible.
Old Oct 18, 2011 | 06:20 PM
turbo2point4
It's possible, but you can pick up a decent srt for $6-8k if you want a nicer one thats when its $10-12k check the srtforums for one, unless you'd rather do the work then do that but if your getting a whole totalled srt then use all the parts possible for a more complete and better swap
Old Oct 19, 2011 | 03:15 PM
Billy Leavitt
Yeah thats Very true! But i do want a nice one! But if im going to spend around 12k for a srt4 i might as well look into STI's to, you can get some nice ones for about 14K.
Old Oct 19, 2011 | 08:01 PM
turbo2point4
All I've heard is sti's suck to do anything to plus the trannys are weak EVO ftw!
Old Oct 20, 2011 | 04:31 PM
Billy Leavitt
as in you think both are ****? lol
Old Oct 23, 2011 | 03:08 PM
turbo2point4
i like the evo 8's or 9's, my wife and i have an '03 evo 8
Old Oct 26, 2011 | 03:13 PM
Billy Leavitt
i like them both to. i just want something thats AWD, and i really like the STIs and the evos. and a 6speed.
i am not sure if the evo8 or evo9 are 6 speed i have only seen 5 speed.
