Mopar Blue Plate Install Question?
Is there a ground wire near the plate that needs to be removed and reconnected when installing the Blue Plate? Is there a Oil Line to the Turbo that needs to be moved or pushed aside? Since this would be a critical area I wanted to insure that I cause no oil leaks if I get and install the plate.
no- some people bend the oil line a little so they can get to the infamous "third bolt" better, but i didn't have to. there is no ground- there is a pink vacuum line, but everything goes back together just like it came apart, but with the bov in between.
if you haven't already, do a search for "mopar bov" install- there are some good tips around here, like investing in a 10 mm ratcheting wrench, and tying the wrench to your wrist, stuff like that.
have fun with it!
have fun with it!
