catch can
Old Mar 29, 2004 | 07:47 PM
  #21
thejuice18's Avatar
thejuice18
Default RE: catch can
thanks, mine should be here by friday this week. what else have you done to you car. if you have a wastegate was it easy to put on?
Old Mar 29, 2004 | 08:24 PM
  #22
dustyloins's Avatar
dustyloins
Hall of Fame Member
No wastegate, I may get the stage 2 though. Additional things are 8.5mm MSD spark plug wires, MPx front strut tower bar, both from Modern Performance, Dei plug wire sheaths from Summit Racing, a not-yet-installed Mopar BOV off of eBay and graphics plus a K&N air filter also off of eBay. I also bought a set of spark plugs from Modern Performance but I (hopefully) won't need those for awhile...I also signed up as a PC (preferred customer) from the guys in the Synthetic Lube section of DF. I've got Mobil 1 in the SRT right now, but will probably switch over to Amsoil pending the results of a ongoing test comparing Mobil 1 and Amsoil that I've referenced in the same section of DF...[sm=smiley20.gif][sm=smiley4.gif][sm=smiley20.gif]
