question about downpipe..
Old Aug 18, 2005 | 10:15 PM
bigham's Avatar
bigham
Default RE: question about downpipe..
so PSI if i get stage 1 and the dp with race pipe i could leave it on all the time or should i not leave it on all the time..
Old Aug 18, 2005 | 10:25 PM
PSI Chick's Avatar
PSI Chick
you can leave it on all the time
Old Aug 18, 2005 | 10:31 PM
bigham's Avatar
bigham
any damage to car or no
and will we feel a big difference
Old Aug 19, 2005 | 03:12 AM
coyoteyz13's Avatar
coyoteyz13
You won't damage anything. Your turbo will spool faster.
Old Aug 19, 2005 | 02:05 PM
bigham's Avatar
bigham
thanks for the input
Old Aug 19, 2005 | 02:25 PM
coyoteyz13's Avatar
coyoteyz13
ORIGINAL: PSI Chick
well the major issue i always had was the electronic cut out. the motors tend to fail, causing the plates to be stuck partialy open. this causes leaks and we all know how good those are.
i also have concerns about the ecu pulling timing with these cut out's. we all know that it takes the ecu time to adjust to new mods and changing conditions. well if you go from a full exhaust to a sudden release point, there's the possibility that the ecu will pull timing thinking that something is wrong. this has been shown to happen with the addition of dp's and catbacks if they are installed and immedietly put on a dyno. so it's possible that it's doing the same on the cut out. now i haven't seen any evidence of this, but i haven't seen much to the contrary either.
If it retards the timing, will the boost level drop?
Old Aug 23, 2005 | 07:49 PM
coyoteyz13's Avatar
coyoteyz13
Bump
Old Aug 23, 2005 | 07:53 PM
PSI Chick's Avatar
PSI Chick
the boost levels should be the same, but the timing would change and cause a reduction in power.
Old Aug 24, 2005 | 02:01 AM
coyoteyz13's Avatar
coyoteyz13
How do you tell if the timing has been retarded?
Old Aug 24, 2005 | 03:39 AM
PSI Chick's Avatar
PSI Chick
unless you have a data logger or a obd, the only real way to tell is that you'll feel it. the car just won't feel as fast as it should.
