Mopar Performance BOV
Old Aug 18, 2005 | 04:55 AM
Olie70's Avatar
Olie70
Default RE: Mopar Performance BOV
ORIGINAL: PSI Chick
i've seen it leak on plenty of cars. on most it will, some it won't. personally i'm not going to take the risk. i had the plate, and i took it off. we then put it on a friend's car and we leak tested both cars. we both held 20psi with no problems, but when the air hose was taken off his boost dropped like a rock while mine stayed with a slow, steady decline. i am glad i removed it, and i'll never put it back on after seeing the difference in a pressurized system. i could hold boost, he couldn't, that's all i needed to see.
I have to agree....come this weekend, going to take mine off.....car used to learch (sp?) forward and pull hard to right during 1st and 2nd gear launches, now, ALOT tamer. When I take it off and if car reverts back to the monster it was, will post and let everyone know. I am not going to sacrifice power and speed for a cool whoosing noise....can't do it....[sm=badidea.gif]
Old Aug 19, 2005 | 03:20 AM
coyoteyz13's Avatar
coyoteyz13
I pressure tested my car for the first time today. No leaks out of the rice plate, but I had three other leaks. Hot and cold side of the FMIC and the hose that comes off of the back of the turbo. It deffinatly holds boost longer now that I tightened the leaks up.
