I NEED HELP
Old Aug 18, 2005 | 04:55 PM
Falconadam71's Avatar
Falconadam71
Default I NEED HELP
Today i Installed the Mopar Conversion Blow off plate on my car. When i go to ship gears at a high rpm instead of making a woosh sound it make like a boggy sound. Also when i get on the gas a lot i can here a sound that sounds like a leaking of air. what do i do someone please help me i dont know why my BOP in not working Thanks
Old Aug 18, 2005 | 05:01 PM
Pressurecooker's Avatar
Pressurecooker
Default RE: I NEED HELP
You need to read the thread currently about 10 lines down concerning the Mopar preformance BOV. They are notorious for leaking.
Old Aug 18, 2005 | 05:03 PM
srt4 driver's Avatar
srt4 driver
Like Pressure Said (most likely you had some problems installing the blue plate special and now its leaking gravy all under your hood)
Old Aug 18, 2005 | 05:07 PM
black05srt4's Avatar
black05srt4
when you installed it did you make sure all the holes lined up with the ones on the turbo???. You could've blocked off the holes accidentally. I would take it off and double check. make sure everything is lined up properly
Old Aug 18, 2005 | 05:21 PM
posthondaremoval's Avatar
posthondaremoval
Yeah, make sure the half moon indentation matches up on the gasket, and make sure it is in the right orientation, as well.
Can you get a torque wrench on there?
Old Aug 18, 2005 | 05:31 PM
srt4 driver
Has anyone tried using Blue RTV goo on these blue things? Like a thin coating on the gasket perhaps?
Old Aug 18, 2005 | 05:36 PM
posthondaremoval
ORIGINAL: srt4 driver
Permatex Hylomar Gasket Dressing can help. If I were to use any that is what I would use. But it is unnecessary.
Old Aug 18, 2005 | 05:42 PM
Falconadam71
I have already took it apart and checked to see if everything was ok but it still just does not Blow off when i shift or rev
Old Aug 18, 2005 | 05:47 PM
posthondaremoval
I am not doubting you, or trying to give you crap. It sounds like it is installed backwards. Lots of people do it, don't feel bad if it is.
Is the half moon facing back towards the back of the car or
towards the front?
Old Aug 18, 2005 | 05:48 PM
coyoteyz13's Avatar
coyoteyz13
Post some pictures of your install. Take it apart and thake pics as you go. This might help. I used the permatex, and I have know leaks that I know of. I am making a leak tester today, so I will find out if I did it right.
