exhausts
Old Sep 13, 2005 | 01:21 AM
bellosiciliano18's Avatar
bellosiciliano18
Default RE: exhausts
i have the perrin turbo back....not loud like most cars w/o cat, but you can def tell when you get on it...sounds sick, def a nice set up
Old Sep 15, 2005 | 11:38 PM
MYSRT4's Avatar
MYSRT4
if you are going to spend the money i recomend a 3" all the way you cant go wrong w/ turbo you need a 3" to get all the horse power but if you are on a budget like me and you are not going up in horse power stage 2 or 3 go with the borla
Old Sep 16, 2005 | 12:08 AM
bigham's Avatar
bigham
ITS ONLY FAST IF YOU CAN BEAT MY SRT
I like alot
Old Sep 17, 2005 | 07:51 AM
BlackDragon's Avatar
BlackDragon
ORIGINAL: srt4 kid
I believe that if you run stage 3 or lower the mopar catback will work just fine. I'm sure there are benefits to running 3 inch exhaust but if you are stage 3 or under you'll be fine. Anyone feel free to correct me if i'm wrong on this.
I have to disagree on one point. We had stage 3 with the maxxfab dp/borla combo, and maxxfab's 3.5-3" o2 housing, and you could feel and hear the restriction in the pressure of the exhaust. We switched to a custom maxxfab 3" T/B, and the difference was immediately noticable...
Any srt in between 300-350hp is right on the borderline of 2 1/2 and 3". Upwards of 350, which is easy with stage 3/toys and bolt-ons, 3 inch is necessary to get the best performance.
Old Sep 19, 2005 | 12:57 PM
coyoteyz13's Avatar
coyoteyz13
ORIGINAL: MChat
I have a 3" turbo-back GHL exhaust, which I modified to add a muffler and an electric cut-out. There are two versions of the GHL, one with a Resonator and one without. Get the one with the Resonator, unless you plan on adding a muffler like I did.
What kind of electric cutout do you have. I have a needswings DP and I am tired of crawling on the groung to uncap it. Have you had any problems?
Old Sep 19, 2005 | 01:29 PM
MChat's Avatar
MChat
I have the McCord (IIRC), it leaks a little but other than that works fine. When it was new it'd stick open sometimes, but now that it's "broken in" I've had no problems.
Old Sep 19, 2005 | 02:54 PM
PSI Chick's Avatar
PSI Chick
a leak isn't a problem for you?
that's why i wouldn't put a cut out on my car.....
Old Sep 19, 2005 | 05:37 PM
coyoteyz13's Avatar
coyoteyz13
My cutout does not leak at all. It is just a pain to take on and off. A wastegate down there would be sweet.
Old Sep 20, 2005 | 08:59 PM
MChat's Avatar
MChat
ORIGINAL: PSI Chick
It's not really noisy, just a little puffing sound coming through the plate.
Old Oct 12, 2005 | 12:37 PM
PONYBOY's Avatar
PONYBOY
You have many to choose from and yes Borla is good. Try www.modacar.com I see they have a large parts list for the SRT-4
