BOV?
Old Sep 15, 2005 | 06:46 PM
rx8driver's Avatar
rx8driver
Default BOV?
So I installed the turbo-xs h-rfl bov. I have a couple of questions. The bov sounds great but I can only hear it blow off after being in boost. Is this normal? The bov is loud and sounds good when driving hard, I just thought I would hear it blow off in vaccum some, or am i crazy.
For instance the car used to boost to 15 psi and spike at 17 psi in 4th gear. Now it is boosting to 13-14 psi and holding there in 4th gear. Is this a problem? The boost seems to be more steady threw all of the gears than it used to be.
Thanks for any comments.
Old Sep 15, 2005 | 07:24 PM
97_silver_venger's Avatar
97_silver_venger
Default RE: BOV?
I am just takeing a stab at this one so i am wrong please someone correct me. The way i undersatnd it, the bov releases the back pressure that occurs when you **** and you intake valves close. If you are driving and are not in boost and shift, the pressure is a lot less and therefore you may or may not hear anything out of the bov.
As for the loss in boost you might have a leak or something else wrong with it, but the installation of a new bov should not decrease your boost from what you got with your old bov.
Hope i helped you a little but once again this is just my 2 cents and if i am wrong or partially right plaese someone correct me.
Old Sep 16, 2005 | 01:07 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: BOV?
ORIGINAL: 97_silver_venger
Pretty funny you had me like [sm=jawdrop.gif] when I firrst read that.
Otherwise correct.
Old Sep 16, 2005 | 03:58 PM
bigham's Avatar
bigham
Default RE: BOV?
nice
