can 225 tires fit on the stock wheels?
Old Oct 3, 2005 | 01:12 AM
srt4 kid's Avatar
srt4 kid
Default can 225 tires fit on the stock wheels?
I was looking at pics of srt-4s on srtforums and there was an srt-4 with what appeared to be powdercoated stock wheels. The wheels were wrapped in 225 tires. Is this possible on the stock wheels? Thanks
Old Oct 3, 2005 | 03:11 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: can 225 tires fit on the stock wheels?
Its not safe. Theres not enough rim to "fully" seal the bead. The absolute widest you can go, and its still pushing it, is a 205. Some people have run 225s on the stock wheels, but at a 6" width....its really not the best idea in the world. Buy wider rims, then buy wider tires.
Old Oct 3, 2005 | 04:10 AM
bigddy9's Avatar
bigddy9
I run 225/45's Dunlop WinterSport M2's on my stock wheels. I run 225/45 Toyo Proxes 4's on my Enkei's. I drove all winter long on my stock wheels and 225's and had no issues at all. I don't think going an wider than a 225 is a good idea, but I don't see any problems with a 225 on stock wheels.
BTW, I think the stock wheels are 7" wide.
Danny
Old Oct 3, 2005 | 02:57 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: bigddy9
Danny
No, danny, they are 6" wide unless you have an acr. then they are 16X7. The stock wheels are 17x6 and lilsparkplug is absolutely right. A 225 is definitely not recomended on a 6" rim like our stocker. There will be a lot of roll, and the bead will not seat properly. If you have to make a sudden emercency turn you could have big problems. You'll be fine if nothing unexpected happens, but if you have to jerk it hard, it could be bad. You will also have no performance gain, since there will be so much roll in the sidewall, so what is the point?
Look at the way your sidewalls balloon out from the rim. For drag racing this is okay, but otherwise is a bad idea if you like to take a lot of hard corners.
Old Oct 3, 2005 | 03:18 PM
Olie70's Avatar
Olie70
ORIGINAL: posthondaremoval
ORIGINAL: bigddy9
Danny
[sm=jawdrop.gif] More found p***.....HA!!!
Old Oct 3, 2005 | 03:20 PM
posthondaremoval
ORIGINAL: Olie70
ORIGINAL: bigddy9
Danny
[sm=jawdrop.gif] More found ****.....HA!!!
Damn Olie, you are on a roll. lol
Old Oct 3, 2005 | 06:09 PM
LilSparkPlug
Olies definitely rolling today! lmao. Yup yup no 225ers......not good. A 215 isnt even recommended by the BFG technical manual for any rim narrower than SEVEN inches. Which is why we have 205s. Why they couldnt just make the wheel wider to support wider tires for the amount of torque our little FWD beast has...I will never know.
Old Oct 3, 2005 | 09:54 PM
bigddy9's Avatar
bigddy9
I stand corrected. I could have sworn the stockers were 7" wide, but apparently I'm wrong. That being said, I have made several "jerk it hard" moves on my winter tires and had no ill effects. I drive my car like I stole it, and have never had any issues. My winter tires didn't look like they were bulged out at all.
Danny
