Mopar BOV Install - Link doesn't work
Old Oct 12, 2005 | 03:56 PM
Hi N Mity's Avatar
Hi N Mity
Default RE: Mopar BOV Install - Link doesn't work
install the 'hard to get to' bolt first. after you have it started, you can snug it up a tiny bit. then you can swivel the plate on that bolt, allowing more room to get to the 3rd bolt. once you get that bolt snugged up a little, you can put the other 2 bolts in. If you had snugged up the 3rd bolt before installing the other 2 bolts, you wont have to work on that bolt as much now. tighten up the 2 easy bolts, then reach under the BOV and finish up the 3rd bolt.
Old Oct 12, 2005 | 08:14 PM
cj8718's Avatar
cj8718
Got this done and I can't believe I did it. Four hours (at least) spent on a mod that doesn't do anything but make noise! It's not like I didn't know this up front but four goddamn hours?
If anyone else is considering this mod my suggestion is if you want the sound, burn a dvd w/ two cymbals clashing and play it whenever you get off the gas - same damn thing and you save yourself a bunch of time, sixty-five bucks and a bunch of skin on your left arm.
Okay, now that the bitchings done I do hafta admit I kinda like the shwooosh. My teenager boys are gonna love it.
