balance shafts
Old Oct 28, 2005 | 05:16 AM
neonfreak1988's Avatar
neonfreak1988
Default balance shafts
hi. does anybody here know if the srt4 motor will run ok without the balance shafts installed, or does removing them create problems? thanks for the input.
Old Oct 28, 2005 | 01:38 PM
MChat's Avatar
MChat
Default RE: balance shafts
I've had mine out since April. No problems here. You will get a bit more in cabin vibration though.
Old Oct 29, 2005 | 05:25 AM
neonfreak1988
thanks man, im not worried about vibration, so i guess i'll go ahead and put the motor back together without them. thanks again for the help.
Old Oct 29, 2005 | 11:20 AM
bigham's Avatar
bigham
what kinda performance gains can you get from removing them
Old Oct 30, 2005 | 02:24 PM
MChat's Avatar
MChat
Not enough to warrant the hassle. But if you have the pan off, or engine apart already then it's worth it.
Maybe 5hp?
Old Nov 16, 2005 | 02:20 AM
BigMac's Avatar
BigMac
I believe you must plug the oil holes that are left exposed when you remove the shafts; otherwise you'll suffer from low oil pressure. That's what I've heard anyway.
Old Nov 16, 2005 | 11:47 AM
MChat's Avatar
MChat
Yea, there is one hole. It's toward the front of the block and its a small (~1/4") hole near the bolt hole for the balance shaft assembly. I used a greased tap to thread the hole and then put silicon on a bolt and threaded it in there and tightened it down.
