stage 1 install, tripping codes???????
Old Oct 28, 2005 | 07:56 PM
turbeaux kid's Avatar
turbeaux kid
Default stage 1 install, tripping codes???????
Ok so I installed my stage 1 and I checked to see if it was tripping any codes. It was saying that I was tripping a P0633 code. I was wondering if anyone know what that code was? I thought I had all the codes but I guess I was wrong., And if anyone knows where I can get a link to all the codes for the srt4 please let me know..........
Old Oct 29, 2005 | 12:59 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: stage 1 install, tripping codes???????
All of the SRT-4's with the Stage 1 (and 2/3) throw that code. The install instructions even mention that. It's nothing to worry about. Enjoy your car.
Dusty
Old Oct 29, 2005 | 01:25 AM
LilSparkPlug's Avatar
LilSparkPlug
I dont throw that code at all....and I have Stage 1.... Hmmm[>:]
Old Oct 29, 2005 | 04:44 PM
Gump's Avatar
Gump
I dont throw any codes with my s2... try resetting your ecu.
Old Oct 29, 2005 | 05:33 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
http://www.modernperformance.com/dcx...tage3kit.shtml
The above link says in part: "It is normal for the Mopar Turbo Upgrade Kits to set the P0633 fault code.......performance will not be affected as a result of this code." Like I said before, I'm 99% certain my Mopar install instructions said the same thing on my Stage 1.
Dusty
Old Oct 29, 2005 | 06:09 PM
71RoadRunner's Avatar
71RoadRunner
They do say that in your Stage 1 instructions and all the Stages do the same just like you said dusty.
Old Oct 29, 2005 | 09:17 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Thank you sir, I'm glad my mind wasn't playing tricks on me!!!!!!! BTW, good to talk to you again......
Dusty
Old Oct 29, 2005 | 10:59 PM
LilSparkPlug
Oh no I dont doubt you at all Dusty!! Im almost positive that when I bought it from Paul, he tripped something off inside the PCM so that I wouldnt ever throw that code. And I havent to this day. So while I do know that your right, my Stage 1 PCM doesnt throw anything....for whatever reason.
Old Oct 31, 2005 | 12:27 PM
TRAV's Avatar
TRAV
P0633-SKIM KEY NOT PROGRAMMED IN PCM
Old Oct 31, 2005 | 02:52 PM
PSI Chick's Avatar
PSI Chick
this code is thrown because the ecu was programed while out of the car. it can be easily fixed, there's a how to somewhere that i can find if people want it. all you have to do is program the skim key into the ecu. it doesn't effect performance and doesn't effect warranty, so it doesn't really matter if it's there or not.
