PERFORMANCE?
Old Nov 3, 2005 | 03:37 PM
flameredsrt's Avatar
flameredsrt
Default PERFORMANCE?
I need some info. i have a 04 with the basic mods(intake,sts,bov,plugs and wires.i came across some extra money and i wanted to get some more upgrades. i want performance but i dont want to do stage 1(getting stage 2 after the first of the year).i was looking at the agp wastegate but would it be necessary with stage 0?with out a boost controller will it do anything for me?if not ideal at this time any suggs. got about 500 to spend.............thanks in advance
Old Nov 3, 2005 | 03:47 PM
TRAV's Avatar
TRAV
Default RE: PERFORMANCE?
I JUST PUT ON A BOOST CONTROLLER(I'M STAGE 0) AND IT IS AN AWESOME MOD. THE TURBO BUILDS POWER SO MUCH FASTER. I STILL HAVE THE STOCK WASTEGATE TOO, WAITING TO GET STAGE 2. THE CONTROLLER I GOT WAS THE HALLMAN PRO RX. COMES WITH 2 SPRINGS AND HAS A CERAMIC BALL. BEST $100 I SPENT ON THE CAR.
Old Nov 3, 2005 | 04:30 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: flameredsrt
My opinion:
Get a good exhaust. You will want it no matter where you take the car, and I personally don't trust a simple boost controler. Get the turbo toys when you go s2 - it has a multi staged boost controller as well as other plusses built in. The first of the year is coming up soon, so skip the wastegate, s2 comes with a good one, and you won't have to mess with vac. lines, which never seal the same way once you pull 'em once.
You could do a Maxxfab downpipe with a side exit pipe for that money, or a 3" dp with a borla exhaust. Both are good choices.
Old Nov 3, 2005 | 07:35 PM
Vettely's Avatar
Vettely
Is there a good exhaust that is NOT louder than stock? Just wishful thinking, probably.
Old Nov 4, 2005 | 12:41 AM
LilSparkPlug's Avatar
LilSparkPlug
Perrin would be the only one Vettely, but thats because it has a central muffler. It gives you power...and its quieter
Old Nov 4, 2005 | 03:53 AM
PSI Chick's Avatar
PSI Chick
i would also suggest an exhaust. very good money spent. also think about some motor mounts, a check valve, throttle body, or even a w/i kit. there's lots of ways to spend $500!
Old Nov 4, 2005 | 12:04 PM
RIPSIGUY's Avatar
RIPSIGUY
Hey Amy, is that one of your ChiaPet frogs? LOL He/She is quite furry! I'm just messin with ya .
Seriously, WTF is that thing?
Old Nov 4, 2005 | 12:08 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
tis a furry hampsty...or hampster
Old Nov 4, 2005 | 01:21 PM
Vettely's Avatar
Vettely
ORIGINAL: LilSparkPlug
Thanks, I will do some research on that.
Old Nov 4, 2005 | 02:27 PM
chasem167's Avatar
chasem167
ORIGINAL: posthondaremoval
My opinion:
Does the stage 2 come with a turbo timer? Im installing one this weekend in the same spot as the toys just to keep the turbo in good condition. It will get its usage even before i put a stage 2 in the car with toys so its not a bad purchase. again just wondering if that was a addition to the stage 2.
